[gdal-dev] Opening gridded xyz data that is out of order
Kurt Schwehr schwehr at gmail.com
Mon Sep 11 06:52:58 PDT 2017
Can you transform the file and swap the y & x when they are in an
alternative order with your choice of python/perl/awk?
On Mon, Sep 11, 2017 at 6:51 AM, Andreas Neumann <a.neumann at carto.net>
wrote:
> Hi,
> Forgot to mention the link to the file, just in case you have time testing
> - see https://services.geo.zg.ch/temp/dtmav.zip (138 MB zipped file).
> Thanks,
> Andreas
> On 11.09.2017 15:43, Andreas Neumann wrote:
>> Hi,
>> I received a DTM from a Swiss province (OpenData) which is of the
>> following format:
>> One coordinate per line, already gridded. See f.e.
>> 2708001.00 1218001.00 1541.52
>> 2708003.00 1218001.00 1542.35
>> 2708005.00 1218001.00 1542.98
>> 2708007.00 1218001.00 1543.58
>> 2708009.00 1218001.00 1544.20
>> 2708011.00 1218001.00 1545.13
>> 2708013.00 1218001.00 1545.88
>> The issue is that further down the file there seems to be an issue of
>> ordering the coordinates. gdalinfo produces the following error:
>> ERROR 1: Ungridded dataset: At line 4125001, change of Y direction
>> gdalinfo failed - unable to open 'DTM_swissALTI3D_XYZ.txt'.
>> If GDAL could open the data - it would open as ungridded data - right?
>> Issue is, this data is already gridded as you can see above. I actually
>> want to save this is a gridded GeoTIFF file for later usage in QGIS.
>> Is there still a chance that GDAL can open this data set, even if
>> coordinates are out of order?
>> How about the gridded vs ungridded aspect of xyz files?
>> Thanks,
>> Andreas
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170911/b7f23d2b/attachment.html>
