[gdal-dev] Opening gridded xyz data that is out of order
Joaquim Luis jluis at ualg.pt
Mon Sep 11 07:45:46 PDT 2017
You could have done it with GMT as well
gmtinfo DTM_swissALTI3D_XYZ.txt -I2
-R2708001/2717999/1210001/1219999
xyz2grd -R2708001/2717999/1210001/1219999 -I2 -GDTM_swissALTI3D_XYZ.grd
and you get a netCDF grid (it can do GeoTIFs too but would need to go see
the docs)
The grid misses a tile of data at the lower right corner
Joaquim
> Hi Mark (and others),
> Your sort command worked like a charm. It was also very fast!
> Now gdalinfo produces this nice information output:
> Driver: XYZ/ASCII Gridded XYZ
> Files: dtmav_sorted.xyz
> Size is 5000, 5000
> Coordinate System is `'
> Origin = (2708000.000000000000000,1210000.000000000000000)
> Pixel Size = (2.000000000000000,2.000000000000000)
> Corner Coordinates:
> Upper Left  ( 2708000.000, 1210000.000)Lower Left  ( 2708000.000,
> 1220000.000)Upper Right ( 2718000.000, 1210000.000)Lower Right (
> 2718000.000, 1220000.000)Center      ( 2713000.000, 1215000.000)Band 1
> Block=5000x1 Type=Float32, ColorInterp=Undefined
>  Min=728.210 Max=2294.290 NoData Value=0
> Now I can open this in QGIS as a normal data source and simply safe as a
> GeoTIFF file.
> Thanks a lot to all who answered so quickly!
> Glad that a simple sort command on the command line helped to solve the
> issue! I will contact the data provider and ask them if they could
> deliver this >data in an already sorted form so that GDAL recognizes it
> as gridded data.
> Andreas
> On 11.09.2017 16:12, Mark Johnson wrote:
>> You must sort the data beforehand- the y position must be sorted
>> properly (ASC or DESC)
>> Standard linux sort program:
>> sort -k2 -n -k1 392_5810.xyz -o 392_5810.sort.xyz
>> (2nd column (y) as numeric, then first column (x) -o = output file
>> As a zip file you can also do:
>> unzip -p 390_5820.zip | sort -k2 -n -k1 -o ../xyz/390_5820.dhhn92.txt
>> that would deal with problem in 1 step.
>> ogr needs to know the range/area to build (minx,miny,maxx, maxy), so
>> when the y switches it assumes a new column.
>> Mark
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170911/3102f0a8/attachment.html>
