[gdal-dev] Opening gridded xyz data that is out of order
Andreas Neumann a.neumann at carto.net
Mon Sep 11 08:04:27 PDT 2017
Hi Joaquim,
Interesting. Thanks for sharing. As always with OpenSource there are
more solutions than just one ;-)
Yes, I am aware about the missing data in the lower right corner - this
is outside of the province and outside of my area of interest.
Thanks and greetings,
Andreas
On 11.09.2017 16:45, Joaquim Luis wrote:
> You could have done it with GMT as well
> gmtinfo DTM_swissALTI3D_XYZ.txt -I2
> -R2708001/2717999/1210001/1219999
> xyz2grd -R2708001/2717999/1210001/1219999 -I2
> -GDTM_swissALTI3D_XYZ.grd DTM_swissALTI3D_XYZ.txt
> and you get a netCDF grid (it can do GeoTIFs too but would need to go
> see the docs)
> The grid misses a tile of data at the lower right corner
> Joaquim
>     Hi Mark (and others),
>     Your sort command worked like a charm. It was also very fast!
>     Now gdalinfo produces this nice information output:
>     Driver: XYZ/ASCII Gridded XYZ
>     Files: dtmav_sorted.xyz
>     Size is 5000, 5000
>     Coordinate System is `'
>     Origin = (2708000.000000000000000,1210000.000000000000000)
>     Pixel Size = (2.000000000000000,2.000000000000000)
>     Corner Coordinates:
>     Upper Left  ( 2708000.000, 1210000.000)
>     Lower Left  ( 2708000.000, 1220000.000)
>     Upper Right ( 2718000.000, 1210000.000)
>     Lower Right ( 2718000.000, 1220000.000)
>     Center      ( 2713000.000, 1215000.000)
>     Band 1 Block=5000x1 Type=Float32, ColorInterp=Undefined
>       Min=728.210 Max=2294.290
>       NoData Value=0
>     Now I can open this in QGIS as a normal data source and simply
>     safe as a GeoTIFF file.
>     Thanks a lot to all who answered so quickly!
>     Glad that a simple sort command on the command line helped to
>     solve the issue! I will contact the data provider and ask them if
>     they could deliver this data in an already sorted form so that
>     GDAL recognizes it as gridded data.
>     Andreas
>     On 11.09.2017 16:12, Mark Johnson wrote:
>>     You must sort the data beforehand
>>     - the y position must be sorted properly (ASC or DESC)
>>     Standard linux sort program:
>>     sort -k2 -n -k1 392_5810.xyz <http://392_5810.xyz> -o
>>     392_5810.sort.xyz <http://392_5810.sort.xyz>
>>     (2nd column (y) as numeric, then first column (x) -o = output file
>>     As a zip file you can also do:
>>     unzip -p 390_5820.zip | sort -k2 -n -k1 -o ../xyz/390_5820.dhhn92.txt
>>     that would deal with problem in 1 step.
>>     ogr needs to know the range/area to build (minx,miny,maxx, maxy),
>>     so when the y switches it assumes a new column.
>>     Mark
>>     _______________________________________________
>>     gdal-dev mailing list
>>     gdal-dev at lists.osgeo.org
>>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170911/9b6f70ca/attachment.html>
