[gdal-dev] Fwd: GeoPKG Zoom Level Calculation
Roarke Gaskill roarke.gaskill at weather.com
Thu Sep 14 04:26:40 PDT 2017
Even,
Thanks for your reply.  I get it now.  :)
I am new to gdal in general.  For context, why does CreateCopy() choose the
nearest zoom level and not SetGeoTransform()?  As a new user, it seems to
me the ZOOM_LEVEL_STRATEGY should apply to both the SetGeoTransform() and
CreateCopy().
Thanks again,
Roarke
On Wed, Sep 13, 2017 at 3:50 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On mercredi 13 septembre 2017 15:38:55 CEST Roarke Gaskill wrote:
> > Hi,
> > In the GDALGeoPackageDataset
> > <https://github.com/OSGeo/gdal/blob/65dea1c999b6b5f692c945ea074b04
> cb5e43eca4
> > /gdal/ogr/ogrsf_frmts/gpkg/ogrgeopackagedatasource.cpp#L1819> class it
> > appears the zoom level in the SetGeoTransform function does not calculate
> > the zoom level correctly. Also, it is different from the zoom level
> > calculation in CreateCopy
> cb5e43eca4
> > /gdal/ogr/ogrsf_frmts/gpkg/ogrgeopackagedatasource.cpp#L4079> function.
> The
> > zoom level calculation in the CreateCopy appears to work as I would
> expect.
> > The transform I am using to test is:
> > [-20037508.342789248, 6176.637812966647, 0.0, 19971868.880408563, 0.0,
> > -6177.590116052211]
> > The CreateCopy zoom level logic produces level 5. Which is what I would
> > expect.
> > The SetGeoTransform zoom level logic is not able to identify a zoom
> level.
> > Is the SetGeoTransform zoom level calculation logic wrong?
> Roarke,
> when using SetGeoTransform() and a pre-defined tiling scheme (here I
> assume you must use GoogleMapsCompatible), the resolution of the
> geotransform matrix passed to SetGeoTransform() must exactly match the base
> resolution of the tiling scheme divided by a power of 2
> >>> 156543.0339280410 / 6176.637812966647
> 25.344376450147266
> which is not a power of 2.
> CreateCopy() in the GPKG implementation with a pre-defined tiling scheme
> identifies the closest zoom level for your source dataset and then resample
> it so its resolution matches exactly one of the zoom levels.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
*Roarke **Gaskill  *|Senior Software Engineer
*e:* roarke.gaskill at weather.com
<http://weather.com/apps> <http://weather.com/apps>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170914/884e4e6d/attachment.html>
