[gdal-dev] git(hub) migration
Regina Obe lr at pcorp.us
Mon Sep 25 01:56:02 PDT 2017
> 1) migrate to git, and remain within the OSGeo infrastructure. This is for
example the case of
> GEOS which uses the Trac git plugin and the GOGS (or is gitea?) git
hosting (https://
> git.osgeo.org/gogs/geos/geos.git). gogs/gitea tries to replicate most
github functionalities,
> but feature parity is still not there (you cannot comment on a commit
e.g). We could still
> offer github as a mirror, which would ease contributions a bit compared to
the current git-
>svn situation, but the "Merge" button from github couldn't (shouldn't) be
used.
If this option is still on the table, I'd be willing to do the work of
moving GDAL svn and trac to OSGeo gogs/gitea infrastructure.
Note interested in helping with move to github, though I would be willing to
help out with fixing the mirroring on github so that tags are correctly
setup as tags (similar to how they are on PostGIS mirror)
https://github.com/postgis/postgis
Sandro already did a proof of concept with GEOS though he didn't officially
move the tickets off of trac.  I have on my list to experiment moving Gogs
to gitea and iron out any issues.
I was thinking trac/git integration might be another possibility though it
sounds from this page, the performance might not be there yet.
https://trac.edgewall.org/wiki/TracGit#DownloadandInstallation
Thanks,
Regina
