[gdal-dev] Shapefile: automatic retrieval of EPSG code
Carl Godkin cgodkin at gmail.com
Mon Sep 25 12:14:00 PDT 2017
On behalf of everyone who has considered written their own code to do
something like this themselves, THANKS!  I'm looking forward to using this
in our code.
carl
On Mon, Sep 25, 2017 at 10:30 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> As part of a AWEOC (*), following a recent email thread about year-long
> issues when importing shapefiles, I've committed a first version of a
> OSRFindMatches() function that iterates through the EPSG database to check
> for one or several matches between the input SRS and the catalog.
> The shapefile driver now uses this function, instead of the more simple
> AutoIdentifyEPSG(), which only worked on a tiny subset of SRS. When a
> single match is found by OSRFindMatches() with an excellent match quality
> (meaning IsSame() returning TRUE), it is automatically picked up by the
> Shapefile driver.
> OSRFindMatches() returns both a list of candidate SRS and a confidence
> value: 0=bad, 100=perfect . Currently if several candidates pass IsSame(),
> they will be returned with 90% confidence. If a SRS doesn't pass IsSame()
> but is the single one to have a PROJCS/GEOGCS name matching the input SRS
> name (name matching is done with a few hardcoded approximation rules), it
> is returned with 50% confidence.
> OSRFindMatches() execution time is :
> - first execution ever: around 500 ms. It will then create files in
> ~/.gdal/$(GDAL_VERSION_MAJOR).$(GDAL_VERSION_MINOR)/srs_cache to speed-up
> later executions
> - first execution in a process, using the above cache: around 100ms
> - later executions in the process: around 10 ms per SRS (55s to identify
> the 5216 entries of GEOGCS and PROJCS from the EPSG database that are valid
> for GDAL)
> So I feel this is good enough to be enabled by default in the shapefile
> driver.
> I've tested & tuned the function:
> - the 5216 above mentionned SRS exported from OGC WKT to ESRI WKT, and
> reimported from ESRI WKT to OGC WKT. 100% confidence single match is
> obtained for most SRS. Except occurences using Polar_Stereographic where
> ESRI WKT lose the scale_factor and other using Hotine_Oblique_Mercator
> where the rectified_grid_angle parametr is lost. But those are probably
> issues with morphToESRI() / morphFromESRI()
> - the SRS definitions at
> http://help.arcgis.com/en/arcgisserver/10.0/apis/rest/pcs.html . Results
> are less good there. Sometimes for good reason: no entry in the EPSG code,
> different projection or datum parameters, etc.
> It could certainly be improved. For example by using instead of the
> back&white IsSame() method a (to-be-created) GetSimilarityLevel() method
> that would compare how different 2 SRS are. More relaxed SRS name
> comparisons would also help (as the 'tokens' making SRS names are separated
> with underscore once 'massaged', you could split on that, and then compare
> how many tokens are in common (or have partial match), and sum the number
> of identical characters, etc..).
> The gdalsrsinfo utility is also enhanced to use the new OSRFindMatches()
> function if you use the -e switch (for epsg).
> For example, with some.prj containing: PROJCS["NAD_1983_StatePlane_
> Texas_Central_FIPS_4203_Feet",GEOGCS["GCS_North_American_
> 1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",
> 6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["
> Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_
> Conic"],PARAMETER["False_Easting",2296583.333333333],
> PARAMETER["False_Northing",9842500.0],PARAMETER["Central_
> Meridian",-100.3333333333333],PARAMETER["Standard_Parallel_
> 1",30.11666666666667],PARAMETER["Standard_Parallel_2",31.88333333333333],
> PARAMETER["Latitude_Of_Origin",29.66666666666667],UNIT["
> Foot_US",0.3048006096012192]]
> $ gdalsrsinfo -e ESRI::some.prj
> EPSG:2277
> PROJ.4 : +proj=lcc +lat_1=31.88333333333333 +lat_2=30.11666666666667
> +lat_0=29.66666666666667 +lon_0=-100.3333333333333 +x_0=699999.9998983998
> +y_0=3000000 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=us-ft +no_defs
> OGC WKT :
> PROJCS["NAD83 / Texas Central (ftUS)",
> GEOGCS["NAD83",
> DATUM["North_American_Datum_1983",
> SPHEROID["GRS 1980",6378137,298.257222101,
> AUTHORITY["EPSG","7019"]],
> TOWGS84[0,0,0,0,0,0,0],
> AUTHORITY["EPSG","6269"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4269"]],
> PROJECTION["Lambert_Conformal_Conic_2SP"],
> PARAMETER["standard_parallel_1",31.88333333333333],
> PARAMETER["standard_parallel_2",30.11666666666667],
> PARAMETER["latitude_of_origin",29.66666666666667],
> PARAMETER["central_meridian",-100.3333333333333],
> PARAMETER["false_easting",2296583.333],
> PARAMETER["false_northing",9842500.000000002],
> UNIT["US survey foot",0.3048006096012192,
> AUTHORITY["EPSG","9003"]],
> AXIS["X",EAST],
> AXIS["Y",NORTH],
> AUTHORITY["EPSG","2277"]]
> It can also return several occurences if there isn't a single candidate
> For example:
> $ gdalsrsinfo -e 'PROJCS["undefined",GEOGCS["ETRS89",DATUM["European_
> Terrestrial_Reference_System_1989",SPHEROID["GRS
> 1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["
> degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["
> latitude_of_origin",0],PARAMETER["central_meridian",
> 27],PARAMETER["scale_factor",0.9996],PARAMETER["false_
> easting",500000],PARAMETER["false_northing",0],UNIT["metre",1]]'
> Confidence in this match: 90 %
> EPSG:3047
> PROJ.4 : +proj=utm +zone=35 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m
> +no_defs
> OGC WKT :
> PROJCS["ETRS89 / UTM zone 35N (N-E)",
> GEOGCS["ETRS89",
> DATUM["European_Terrestrial_Reference_System_1989",
> AUTHORITY["EPSG","6258"]],
> AUTHORITY["EPSG","4258"]],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",27],
> PARAMETER["false_easting",500000],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AUTHORITY["EPSG","3047"]]
> EPSG:3067
> +no_defs
> OGC WKT :
> PROJCS["ETRS89 / TM35FIN(E,N)",
> GEOGCS["ETRS89",
> UNIT["metre",1,
> AXIS["Easting",EAST],
> AXIS["Northing",NORTH],
> AUTHORITY["EPSG","3067"]]
> EPSG:5048
> +no_defs
> OGC WKT :
> PROJCS["ETRS89 / TM35FIN(N,E)",
> GEOGCS["ETRS89",
> UNIT["metre",1,
> AUTHORITY["EPSG","5048"]]
> EPSG:25835
> +no_defs
> OGC WKT :
> PROJCS["ETRS89 / UTM zone 35N",
> GEOGCS["ETRS89",
> UNIT["metre",1,
> AUTHORITY["EPSG","25835"]]
> Regards,
> Even
> (*) Autumn Week-End Of Code
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170925/54549ba3/attachment-0001.html>
