[gdal-dev] Running Tests
Joaquim Luis jluis at ualg.pt
Tue Sep 26 10:01:24 PDT 2017
On Tue, 26 Sep 2017 15:27:59 +0100, Even Rouault
<even.rouault at spatialys.com> wrote:
> On mardi 26 septembre 2017 15:08:09 CEST Joaquim Luis wrote:
>> >> P.S. - It seems strange to use python as a CI interface to a C/C++
>> >> library.  Is there a reason the test harness isn't in C/C++?
>> > Mateusz already answered on that. Writing Python tests is
>> faster/easier
>> > than C/C++ ones. We/I tend to limit C/C++ written tests to part of the
>> > API not available >through the Python API.
>> That's where Julia might help. From Julia we can call any of the C
>> functions directly from the gdal lib without needing to compile
>> anything.
>> There is this Julia wrapper https://github.com/visr/GDAL.jl but I
>> confess
>> that never used it and it probably does not provide wrappers to all
>> functions. Bur new ones are not difficult to write.
> Actually there's a similar mechanism in Python with the ctypes module:
> https://docs.python.org/3/library/ctypes.html
> I had used it a bit. For example in
> https://trac.osgeo.org/gdal/browser/trunk/autotest/gcore/testnonboundtoswig.py#L166
> Downside of this approach is that if you could get the function
> prototype wrong
> and a runtime crash, as there's no checking against the .h files.
> Even
Right, but in Julia a function wrapper may be as simple as
  function getdriverbyname(arg1)
      checknull(ccall((:GDALGetDriverByName,libgdal),Ptr{GDALDriverH},(Cstring,),arg1))
end
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170926/453e2006/attachment-0001.html>
