[gdal-dev] Opening VRT files within zip archive using /vsizip
Scott Arko saarko at alaska.edu
Tue Sep 26 14:25:50 PDT 2017
Thank you so much Even.  That is an amazing fast turnaround.
On Tue, Sep 26, 2017 at 1:21 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On mardi 26 septembre 2017 13:08:18 CEST Scott Arko wrote:
> > Hello,
> > I have found an odd behavior using the /vsizip driver and I'm hoping
> > someone on this list can explain what is happening.
> Scott,
> this is a GDAL bug. I've just fixed it per
> https://trac.osgeo.org/gdal/ticket/7056
> The Python bindings are more sensitive to errors than the C/C++ code, so
> when an error is emitted and not cleared, they will refuse to open the
> dataset.
> No workaround I can think of, apart applying the fix in the ticket, or
> unzipping the file.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Scott Arko
Alaska Satellite Facility Deputy Director
University of Alaska Fairbanks
903 Koyukuk Drive
Fairbanks, AK 99775
Phone: (907) 474 - 5570
email:  saarko at alaska.edu
http://www.asf.alaska.edu
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170926/27dfb8f3/attachment.html>
