[gdal-dev] Compression Artifacts After Merging Imagery
Jacob Adams Jacob.Adams at cachecounty.org
Thu Sep 28 10:15:57 PDT 2017
Evan,
Thanks for your help. Adjusting the nearblack parameters and using
-setalpha instead of -setmask got the mask working as expected.
I'd normally agree with you on mid-process compression, and if I were
using the data for any kind of analysis I would do as little compression
as possible. However, with this project I'm pressed for space and I'm
only trying to create an aerial imagery basemap. I did a quick test
compressing a single tile 10 times with gdal_translate and the output
was adequate for my project. There was an identifiable softening to the
image at the pixel-level, but the imagery was gathered at 3" per pixel.
On a different topic altogether, how would I go about contributing to
the doxygen-created documentation? In playing around with gdal_rasterize
I discovered that it's not clear in the current docs what options
trigger creation of a new raster instead of overwriting an existing
raster. My C++ skills are very rusty, but if I'm reading the source code
properly, the options -of, -init, -a_nodata, -a_srs, -te, -a_ullr, -co,
-ot, -ts, -outsize, -tr, and -tap set the bCreateOutput flag True. I'd
like to add a note explaining this so that someone else doesn't make the
same beginner's mistake I did of trying to specify creation options on
an existing dataset ;) Is this something I open a ticket for, or is
there a more direct way?
Thanks,
Jacob Adams
GIS Specialist, Cache County
>>> Even Rouault <even.rouault at spatialys.com> 9/25/2017 5:01 PM >>>
On lundi 25 septembre 2017 16:16:26 CEST Jacob Adams wrote:
> Oh ye great minds of the GDAL world, I've run into a problem that
I've not
> been able to solve.
> I have aerial imagery comprised of about 1500 jpegs that I am trying
to
> merge together into three large (~18gb) jpeg‑compressed geotiffs to
be
> served by Geoserver. The images are tiled such that they shift down
about
> 100 pixels (out of ~7000) every so often. With a pure gdal_merge or
> gdalwarp mosaic, this leaves compression artifacts in the nodata
spaces
> along the borders. The cause of these artifacts seems to be explained
in
> Evan's comments on this ticket:
https://trac.osgeo.org/gdal/ticket/5102).
> I tried pre‑processing a handful of the tilesinto geotiffs with the
> following three commands based on a similar discussion in February
(http://lists.osgeo.org/pipermail/gdal‑dev/2017‑February/046027.html):
> nearblack ‑co TILED=YES ‑of Gtiff ‑nb 0 ‑near 0 ‑setmask ‑o temp1.tif
I think one issue is in the above nearblack invocation. Did you check
temp1.tif is "clean" by
displaying it ?
Basically by setting ‑near 0, you say that nearblack should expect a
very clean frontier
between nodata areas and valid areas. Whereas JPEG decompression
artifacts in such a
situation will result in intermediate values in a few pixels beyond the
border.
I'd suggest trying with the default of nearblack, ‑near 15 and ‑nb 2,
and tune them if needed.
>     gdal_translate ‑co TILED=YES ‑co COMPRESS=JPEG ‑co
PHOTOMETRIC=YCBCR ‑b 1 ‑b 2 ‑b
3 ‑mask 4 ‑‑config GDAL_TIFF_INTERNAL_MASK YES temp2.tif Tile1_out.tif
You shouldn't JPEG compress intermediate products. This will decrease
image quality. Only
apply it to the final stage of your workflow.
Even
Spatialys ‑ Geospatial professional services
http://www.spatialys.com
