[gdal-dev] ogr2ogr and nlt question
Andreas Neumann a.neumann at carto.net
Thu Sep 28 23:32:07 PDT 2017
when using ogr2ogr I can fix the geometry type for cases where I use SQL
statements.
Can I use nlt multiple times? In my case I would like to specify -nlt
CONVERT_TO_LINEAR to convert from CompounCurve to Polygon and then use
-nlt POLYGON to tell it you are really a POLYGON. Is this possible to
use the -nlt parameter twice?
Thank you for your reply,
Andreas
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170929/8290fdd5/attachment.html>
