[gdal-dev] Gdal2tiles gains parallel processing features
Angelos Tzotsos gcpp.kalxas at gmail.com
Fri Sep 29 09:12:13 PDT 2017
Thank you for this feature!
Best,
Angelos
On 09/29/2017 06:59 PM, Even Rouault wrote:
> On vendredi 29 septembre 2017 17:50:11 CEST Grégory Bataille wrote:
>> Hi all,
>> I just wanted to announce that after a few months of work (took long, I got
>> lazy), *gdal2tiles has gained parallel computing abilities*
>> It is now *on trunk*.
> Thanks for your great work on this
>> - Because the rewrite + the pararellization are a big and risky work (since
>> there were no tests really), there is a new gdal2tiles_old.py script on
>> trunk to provide an easy "back-out" for people who would get into trouble
>> in their production
> Note: I actually removed gdal2tiles_old.py when merging your work back into SVN (should
> have told you before). It was the same as the version you can find in the 2.2 branch, so one
> could still grab it from there if really needed.
> Even
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Angelos Tzotsos, PhD
Charter Member
Open Source Geospatial Foundation
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170929/439dbba3/attachment.html>
