[gdal-dev] Understanding VSI caching
Andrea Aime andrea.aime at geo-solutions.it
Mon Apr 9 12:03:12 PDT 2018
On Mon, Apr 9, 2018 at 8:58 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Which disk caching are you refering too ? There's some disk caching for the
> WMS driver, but that's all
"In addition, a global least-recently-used cache of 16 MB shared among all
downloaded content is enabled by default, and content in it may be reused
after a file handle has been closed and reopen. Starting with GDAL 2.3, the
size of this global LRU cache can be modified by setting the configuration
option CPL_VSIL_CURL_CACHE_SIZE (in bytes)."
and I see in the code:
https://github.com/OSGeo/gdal/blob/master/gdal/port/cpl_vsil_curl.cpp#L203
(btw, there is no path, does it mean the file is created in the current
directory?)
> (well there's some provisional code for disk caching in /vsicurl/ but it is
> not compiled by default, and probably broken. There was some discussion
> recently on the ML about this if I remember well)
I'll check the archives.
Cheers
Andrea
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39  339 8844549
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180409/8c953241/attachment.html>
