[gdal-dev] Use of C++ iterators in API
Kurt Schwehr schwehr at gmail.com
Wed Apr 11 05:10:53 PDT 2018
The auto&& is really confusing.
-kurt
On Tue, Apr 10, 2018 at 2:41 PM, Mateusz Loskot <mateusz at loskot.net> wrote:
> On 10 April 2018 at 23:06, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > On mardi 10 avril 2018 22:34:56 CEST Mateusz Loskot wrote:
> >> On 10 April 2018 at 22:06, Even Rouault <even.rouault at spatialys.com>
> wrote:
> >> > Just wanted to advertize the recent new introduction of C++ iterators
> >> Good one, thanks!
> >> >     for( auto&& poLayer: poDS->GetLayers() )
> >> Do the iterators return a proxy reference hence the tutorial prefers
> >> auto&& over plain auto&?
> >> (ie. like std::vector<bool> iterator does)
> > Not completely sure to understand what a proxy reference is (C++11 stuff
> is
> > still very new to me, and I don't pretend to master C++98, so ...), but
> I feel
> > that must be close to what I have used in some cases, particularly wen
> > iterating over fields of a features, or points of a linestring.
> I didn't look at the iterators impl. yet.
> I just looked at your example and wondered if there are proxies
> - for GDAL/OGR, those could be necessary, I imagine.
> I mean a proxy as an object that 'looks' like a reference.
> It's often necessary to for (proxied) collections of objects that can not
> be
> accessed directly, via regular pointers/references.
> > I read in some tutorial that using auto&& worked in all situations,
> including
> > when the returned reference was const, so now I just use that everywhere.
> auto&& is most useful when container<T>::reference returns a proxy object,
> which would not bind to auto& (it would bind to auto const& though).
> > In fact the nature of the object which is returned depends on the
> iterator,
> > and as documented in the API, for the sake of implementation simplicity,
> those
> > iterators do not necessarily respect the whole semantics of iterators.
> > That is if you do
> > auto iter = poLineString->begin();
> > OGRPoint& oPoint = *iter;
> > ++iter;
> > OGRPoint& oAnotherPoint = *iter;
> > In fact &oAnotherPoint == &oPoint.
> At first, it seems like they model the input iterators, single-pass
> iterator category
> http://en.cppreference.com/w/cpp/concept/InputIterator
> > So basically you should only use them in range based loops, where you
> don't
> > really manipulate the iterator and cannot do stuff like the above.
> Or, use like any input iterators, seems safe.
> > I guess the "correct" solution would have been to return a OGRPointProxy
> that
> > would keep a link to the linestring and the point index. But not sure
> how you
> > would do that for a const iterator where the operator * is supposed to
> > returned a const reference...
> Or reference-like proxy like std::vector<bool> does.
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180411/7064601d/attachment-0001.html>
