[gdal-dev] gdalinfo error and subsequent segfault with proj-5.0.x
Markus Metz markus.metz.giswork at gmail.com
Sun Apr 15 14:05:42 PDT 2018
On Sun, Apr 15, 2018 at 10:07 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> > OK, I recompiled gdal-2.2.4 --with-static-proj4 and got
> > ldd libgdal.so | grep proj
> >     libproj.so.13 => /usr/local/lib64/libproj.so.13 (0x00007fe2ff181000)
> >     libproj.so.12 => /lib64/libproj.so.12 (0x00007fe2f31c7000)
> > gdalinfo now runs fine and produces expected results.
> > I'm still concerned about the output of ldd libgdal.so
> Yes that's not sane. That means that GDAL links to a library that links
to the
> system libproj (/lib64/libproj.so.12), whereas GDAL directly links to your
> custom libproj 5 build ( /usr/local/lib64/libproj.so.13) . That may crash
as
> well.
> As proj 5.0.1 is (I believe) ABI compatible with previous releases, one
> potential hack is to make
> sudo ln -s /usr/local/lib64/libproj.so.13 /usr/local/lib64/libproj.so.12
> and define LD_LIBRARY_PATH to point to /usr/local/lib64/
> A cleaner solution would be to identify the GDAL dependenci(es) that link
to
> /lib64/libproj.so.12 and rebuild them against the one in
 /usr/local/lib64/
> libproj.so.13
Not too many on my test system. So far, GDAL is working for me now with
PROJ-5.0.x. If I encounter any problems later on, I will heed your advice.
Thanks a lot for your help!
Markus M
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180415/09a81f1a/attachment.html>
