[gdal-dev] os.remove and os.unlink in the testsuite
Even Rouault even.rouault at spatialys.com
Mon Apr 16 02:41:34 PDT 2018
On lundi 16 avril 2018 19:33:33 CEST Ben Elliston wrote:
> Hi Even
> What do you think about adding some convenience functions to the
> gdaltest module like "try_remove" and "try_unlink" that never throw an
> exception if the file doesn't exist?  This would remove a lot of lines
> like these from the test cases:
> try:
>   os.unlink('some file')
> except OSError:
>   pass
You can use gdal.Unlink(filename) and gdal.RmdirRecursive(dirname). They will
not throw any exception or error message.
Even
http://www.spatialys.com
