[gdal-dev] ogr2ogr JSON -> Shapefile Failing
Cechini, Matthew F. (GSFC-423.0)[Science Systems & Applications, Inc.] matthew.f.cechini at nasa.gov
Wed Apr 18 13:00:40 PDT 2018
All,
    Once upon a time (GDAL 1.x) I was able to convert the following JSON to Shapefile without errors.  However with GDAL 2.x I am not.  Any assistance you can provide is welcome.  I’m running a simple ` ogr2ogr -f "ESRI Shapefile" -preserve_fid <out> <in>` command.
  "crs":
    "type": "name",
    "properties":
      "name": "EPSG3413"
  "type": "FeatureCollection",
  "features": [
    "geometry":
      "type": "Point",
      "coordinates": [324117.76729052397, 844135.46348421532]
    "type": "Feature",
    "id"  : 230,
    "properties":
      "direction" : "T",
      "ident"     : 230,
      "id"        : 230,
      "day_offset": 0,
      "label"     : "00:44",
      "day_night" : "D",
      "time"      : "00:45",
      "datetime"  : "2017-01-01T00:45:00 UTC"
These are the errors I am seeing:
ERROR 6: Can't create fields of type Time on shapefile layers.
Warning 1: Feature id not preserved
Thanks,
Matt
Matthew Cechini
Contractor, Science Systems and Applications, Inc.
NASA GIBS Systems/Software Engineer
410.205.6272
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180418/bce5f796/attachment.html>
