[gdal-dev] ogr2ogr projection issues
William Roper roper.william at gmail.com
Thu Apr 19 01:09:16 PDT 2018
Hi all,
I've been doing what i thought was a fairly routine merging of shapefiles
and have encountered some unexpected projection issues. If I fail to define
a target srs (-t_srs flag) then the features end up overlaying each other.
I describe the issue in much more detail along with screen shots here:
https://gis.stackexchange.com/questions/279992/what-is-causing-ogr2ogr-to-fail-to-merge-shapefiles-without-a-reprojection?noredirect=1#comment447102_279992
You can see the two scripts I've been using here:
https://gist.github.com/GeoWill/880e0ee973f6e3b4faad96b72eed43d9
Any pointers to better understand what might be going on greatly
appreciated!
Will
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180419/50ad48d9/attachment.html>
