[gdal-dev] Warping EUMetsat MSG-4 MPE dataset to webmercator projection
Andre Joost andre+joost at nurfuerspam.de
Wed Apr 25 06:09:20 PDT 2018
Am 25.04.18 um 14:45 schrieb Andre Joost:
> Am 25.04.18 um 14:29 schrieb Andre Joost:
>> Just checked here: It worked up to GDAL 2.2.3 (from Gisinternals) on the
>> full target extent, and fails with the current 2.2.4.
> ... and gdal 2.4.0dev from Gisinternals works the same as 2.2.3.
> So only the OSGEO4W version 2.2.4 fails. Maybe because of PROJ 5.0.1?
Seems to be. After downgrading to PROJ 4.9.3 it works again, GDAL 2.2.4
and gdal-dev.
HTH,
Andre Joost
