[gdal-dev] Warping EUMetsat MSG-4 MPE dataset to webmercator projection
Menno van Scheers - HUSS menno at huss.nl
Thu Apr 26 01:26:19 PDT 2018
Potential fix seems to be merged with master of proj4.
Can now successfully warp the dataset.
Thanks !
Menno van Scheers
From: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Even Rouault
Sent: woensdag 25 april 2018 22:12
To: gdal-dev at lists.osgeo.org
Cc: Andre Joost <andre+joost at nurfuerspam.de>
Subject: Re: [gdal-dev] Warping EUMetsat MSG-4 MPE dataset to webmercator projection
On mercredi 25 avril 2018 19:20:17 CEST Andre Joost wrote:
> Am 25.04.18 um 15:50 schrieb Kristian Evers:
> > Andre,
> > The PROJ 5.0.1 OSGeo4W installation is faulty so that may be the
> > problem. Specifically the null grid is not being installed in the
> > 5.0.1 package as reported on the mailing list [0]. This has not been
> > resolved yet. Try copying in the null grid to C:\OSGeo4W64\share\proj
> > and see if that changes anything. You can use the file from your
> > current 4.9.3 installation.
> That does not improve the situation with gdalwarp. I will do some tatest
> with cs2cs later.
I've tracked the error down to pj_transform() implementation in proj 5. A potential fix is in https://github.com/OSGeo/proj.4/pull/955
This is specific to using the proj.4 API of proj5.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180426/a97194b9/attachment-0001.html>
