[gdal-dev] VRT pixel functions on tiled vrt
Even Rouault even.rouault at spatialys.com
Thu Apr 26 10:59:57 PDT 2018
On jeudi 26 avril 2018 12:56:10 CEST William Kyngesburye wrote:
> So, a vrt of a vrt?
Yes
> I wanted to avoid that, because as I understand the source, it reads each
> raster in the derived band as a single numpy array, which would be all the
> tiled rasters together.
No, if you use gdal_translate, it will process the source by reasonable chunks, so you
should be able to process arbitrarily large sources.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180426/ecd85ba6/attachment.html>
