[gdal-dev] LIBKML C#
Jamo adam.jamison at portbris.com.au
Mon Apr 30 22:53:16 PDT 2018
Hey Team,
I'm starting to delve into FDO, OGR and GDAL for exporting to some
pre-defined formats (SDF, GML, KML, GeoJson etc etc)
I'm trying to interpret the OGR / GDAL driver documentation for the LIBKML
driver it mentions setting the environment variable for LIBKML_USE_DOC.KML
.... is this an option on the createdatasource?
string[] options = new string[] { "LIBKML_USE_DOC.KML=no"};
OSGeo.OGR.DataSource ds = drv.CreateDataSource(someKMZ, options);
It isn't having the desired outcome.... the KMZ file still contains network
link files to subset kml files within the kmz .....
I'm guessing once I understand these options / environment variables the
others will just follow suite.
Cheers
Jamo
MapGuide Maestro 6.0.0.8587
MapGuide Opensource 3.0.0.8701
Fusion, PHP, Apache
Windows 7 Pro SP1
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
