[gdal-dev] edit geometry with query where
Jérôme Seigneuret jerome.seigneuret at gmail.com
Thu Aug 2 08:03:15 PDT 2018
Thanks!
I have create a bug report. Response is actually reversed to yours
http://issues.qgis.org/issues/19529
Are you also dev on QGIS?
Le jeu. 2 août 2018 16:58, Even Rouault <even.rouault at spatialys.com> a
écrit :
> On jeudi 2 août 2018 16:52:19 CEST Jérôme Seigneuret wrote:
> > Hi,
> > I use QGIS to edit layers and in this soft there is no possibility to
> edit
> > geometry if query where exist. QGIS use OGR driver to read and write
> > geometry. I am also an ArcGIS user and I don't have any problem for
> editing
> > my data with query where definition.
> > OGR can't really work for editing geometry on shapefile when a query
> > definition is set?
> That should generally work. The limitation is rather on the QGIS side and
> should be reported in its bug tracker, if not already reported.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180802/3ef94455/attachment.html>
