[gdal-dev] Is there "--config GDAL_TIFF_INTERNAL_MASK YES" C#	equivalent???
    Even Rouault
    even.rouault at spatialys.com
    Tue Aug  7 23:33:09 PDT 2018
On mardi 7 août 2018 20:19:58 CEST Dmitriy T. wrote:
> How to use a bunch:
> Dataset image = Gdal.OpenShared(sourceCopy, Access.GA_ReadOnly);
> Gdal.wrapper_GDALTranslate(translatedFile, image, options, null, null);
> to create a JPEG-compressed TIFF with internal mask from a RGBA dataset (in
> C#)?
> I'm interested in the C# equivalent of a call *--config
> GDAL_TIFF_INTERNAL_MASK YES*.
In a previous reply, I missed the fact that --config x y isn't expanded by
utility-as-a-library-function, but only by the binaries
So you have to call
Gdal.SetConfigOption("GDAL_TIFF_INTERNAL_MASK", "YES")
or set is as an environment variable
before calling
Gdal.wrapper_GDALTranslate()
Even
http://www.spatialys.com
