[gdal-dev] Does ogr2ogr -overwrite truncate also the spatial index in GeoPackage?
Even Rouault even.rouault at spatialys.com
Tue Feb 6 04:53:49 PST 2018
Jukka,
Which version do you use ? If it is a trunk version before Jan 23,
you may run into the bug fixed by https://trac.osgeo.org/gdal/
changeset/41325
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180206/e2f6cbf7/attachment.html>
