[gdal-dev] Resulting geometry from OGRGeometry::difference somehow got simplified
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Tue Feb 6 13:48:02 PST 2018
mikeucfl wrote
> So if anyone sees a similar issue, it's something internally with GEOS but
> I
> didn't have enough time to track it down. Re-projecting to something using
> meters does help though.
If you could share couple of problematic geometries for example as WKT then
somebody else could have a try as well.
-Jukka Rahkonen-
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
