[gdal-dev] S57 objects’ catalog reload
Even Rouault even.rouault at spatialys.com
Mon Feb 12 05:43:57 PST 2018
Jerome,
> Thank you for your quick answer,
> We work with C#, and unfortunately, we didn’t find GDALDriverManager API.
There's in fact a more radical solution, and that should be available in C# as it is in the generic
SWIG .i files
In Python (and likely the same in C#):
gdal.GDALDestroyDriverManager()
gdal.AllRegister()
> Instead, we tried algorithm you proposed with OGR
> Driver.DeRegister()/Register() : this does not work, csv change is not
> taked into account (csv file seems to be cached)
Yes, Driver.DeRegister() just removes the driver from the list of drivers that are tried, but
that doesn't destroy it.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180212/f84ad50c/attachment.html>
