[gdal-dev] ZSTD compression for GeoTIFF
Even Rouault even.rouault at spatialys.com
Wed Feb 14 07:15:22 PST 2018
I've just pushed in libtiff upstream, and its internal copy in GDAL, support for zstandard/
zstd compression [1], and the appropriate changes in the GDAL GeoTIFF driver.
This requires building libtiff (or GDAL with its internal libtiff copy) against libzstd >= 1.0
My findings are that single-core compression is at least twice faster with zstd than with
deflate, for equivalent or better compression rate. Decompression is a bit faster, but not
that significantly.
So a compelling use case for zstd is potentially in complex processing chains where you
have many intermediate internal products. At that point of adoption, I'd not recommend it
for consumer-facing products.
Even
[1] https://github.com/facebook/zstd
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180214/43f54da8/attachment.html>
