[gdal-dev] Check validity of geometries before writing them into vector tiles?
Even Rouault even.rouault at spatialys.com
Wed Feb 14 07:34:19 PST 2018
On mercredi 14 février 2018 15:10:57 CET Rahkonen Jukka (MML) wrote:
> Hi,
> I admit that my test was somewhat lunatic but I took some random dataset
> from Finland with 68101 polygons and converted data into MVT with default
> settings which means that minzoom was 0.  As a result 12196 of the source
> polygons were written into the 0-level protobuf tile (in EPSG:3067 gridset)
> and none of the polygons is valid. Most polygons have too few points and
> those which have enough points have self-intersections.
> Perhaps there should be some sort of geometry validator in the writer chain?
There is some geometry validation, but it is not white&black. In my tests, with the
ne_10m_admin_1_states_provinces dataset, when I initially implemented very strict
geometry validation, a number of polygons were completely dropped, so I ended up
implementing a more relaxed logic: for an outer ring, it after conversion to integer
coordinates, it is not valid (with GEOSIsValid() testing), then do : buffer( tolerance) followed
by bufffer(-tolerance) followed by simplifypreservetopology(tolerance) (where tolerance is 2
* tile_dim_in_crs_unit / EXTENT) followed by a new round of integer coordinates conversion.
If that's still not valid, keep it.
For an inner ring, drop it if when included in the outer ring, the resulting polygon is not valid
Perhaps you could play with the SIMPLIFICATION and SIMPLIFICATION_MAX_ZOOM options ?
Perhaps you should also use an already simplified layer for the lowest zoom level (see the
CONF option)
Are you sure you get polygons with less than 4 points ? Normally they should be discarded.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180214/f7d5b601/attachment.html>
