[gdal-dev] Creating Cloud Optimized GeoTIFFs
Kurt Schwehr schwehr at gmail.com
Wed Feb 14 11:00:01 PST 2018
(working from pretty close to head...)
A follow up question on how to create cogeo files...
I appear to need to do additional work to set BLOCK_OFFSET_?_?.  How do I
go about this?
I'm trying to create a cogeo without gdal_translate in java by using create
and createcopy like this:
https://gist.github.com/schwehr/39680bec7fd8e3e3f840122ea3bafc65
However,  I get this failure when checking the result:
validate_cloud_optimized_geotiff.py cogeo.tif
  File "validate_cloud_optimized_geotiff.py", line 144, in validate
    data_offset = int(main_band.GetMetadataItem('BLOCK_OFFSET_0_0', 'TIFF'))
TypeError: int() argument must be a string, a bytes-like object or a
number, not 'NoneType
If I use gdal_translate on the result form the java, it validates.
gdal_translate -co COMPRESS=LZW -co TILED=YES -co COPY_SRC_OVERVIEWS=YES
cogeo.tif cogeo2.tif
validate_cloud_optimized_geotiff.py cogeo2.tif
cogeo2.tif is a valid cloud optimized GeoTIFF
gdalinfo -mdd all -listmdd -mm cogeo.tif > cogeo.tif.info
gdalinfo -mdd all -listmdd -mm cogeo2.tif > cogeo2.tif.info
diff -u cogeo{,2}.tif.info
--- cogeo.tif.info 2018-02-14 10:54:27.050423325 -0800
+++ cogeo2.tif.info 2018-02-14 10:54:41.862227514 -0800
@@ -1,5 +1,5 @@
 Driver: GTiff/GeoTIFF
-Files: cogeo.tif
+Files: cogeo2.tif
 Size is 743, 372
 Coordinate System is:
 GEOGCS["WGS 84",
@@ -19,8 +19,8 @@
 Metadata:
   AREA_OR_POINT=Area
 Metadata (DERIVED_SUBDATASETS):
-  DERIVED_SUBDATASET_1_NAME=DERIVED_SUBDATASET:LOGAMPLITUDE:cogeo.tif
-  DERIVED_SUBDATASET_1_DESC=log10 of amplitude of input bands from
cogeo.tif
+  DERIVED_SUBDATASET_1_NAME=DERIVED_SUBDATASET:LOGAMPLITUDE:cogeo2.tif
+  DERIVED_SUBDATASET_1_DESC=log10 of amplitude of input bands from
cogeo2.tif
 Image Structure Metadata:
   COMPRESSION=LZW
   INTERLEAVE=BAND
Files: cogeo.tif
Size is 743, 372
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0],
    UNIT["degree",0.0174532925199433],
    AUTHORITY["EPSG","4326"]]
Origin = (116.349975262217256,39.975075059082918)
Pixel Size = (0.000134747292618,-0.000134747292618)
Metadata domains:
  IMAGE_STRUCTURE
  (default)
  DERIVED_SUBDATASETS
Metadata:
  AREA_OR_POINT=Area
  DERIVED_SUBDATASET_1_DESC=log10 of amplitude of input bands from cogeo.tif
  COMPRESSION=LZW
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  ( 116.3499753,  39.9750751) (116d20'59.91"E, 39d58'30.27"N)
Lower Left  ( 116.3499753,  39.9249491) (116d20'59.91"E, 39d55'29.82"N)
Upper Right ( 116.4500925,  39.9750751) (116d27' 0.33"E, 39d58'30.27"N)
Lower Right ( 116.4500925,  39.9249491) (116d27' 0.33"E, 39d55'29.82"N)
Center      ( 116.4000339,  39.9500121) (116d24' 0.12"E, 39d57' 0.04"N)
Band 1 Block=256x256 Type=Float32, ColorInterp=Gray
  Description = B5
    Computed Min/Max=0.000,0.000
  Overviews: 372x186, 186x93, 93x47, 47x24, 24x12
On Sun, Dec 10, 2017 at 5:34 PM, Kurt Schwehr <schwehr at gmail.com> wrote:
> Thanks Even for the feedback.  There have be a few offline discussions
> going on and Even added some notes to the document on Trac:
> https://trac.osgeo.org/gdal/wiki/CloudOptimizedGeoTIFF?
> action=diff&version=11
> <https://www.google.com/url?sa=D&q=https%3A%2F%2Ftrac.osgeo.org%2Fgdal%2Fwiki%2FCloudOptimizedGeoTIFF%3Faction%3Ddiff%26version%3D11>
> This stems from me switching Earth Engine from LZW to DEFLATE when
> exporting GeoTIFFs (and I added tiling).  We have a report from a user that
> ENVI 5.4 (and 5.1) Classic can't read the resulting images but QGIS &
> ArcGIS can.  I'm reverting exports back to LZW compression.
> On Wed, Nov 15, 2017 at 6:02 AM, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> On mardi 14 novembre 2017 14:20:58 CET Kurt Schwehr wrote:
>> > Hi Even,
>> > I have some follow up questions on Cloud Optimized GeoTIFFs:
>> The main constraint of C.O.G is that all the IFD definitions are at the
>> beginning of the file, to avoid seeking at various points in it. Other
>> parameters are pretty much unspecified.
>> > * Is there a preferred/better INTERLEAVE if there is more than one band?
>> Depends on access patterns. If as soon as you process one pixel you need
>> to access the value for all bands, then INTERLEAVE=PIXEL is better, and it
>> will result in smaller sizes of StripOffsets/TileOffsets and
>> StripByteCount/TileByteCount arrays
>> > * Is there a preferred tile blocksize? You have 512 in your examples.
>> Are
>> > there any major trade offs between using 128, 256, 512, or 1024 for x
>> and y
>> > block sizes?
>> Too small blocksizes will result in larger ...Offsets and ...ByteCount
>> arrays.
>> > * Should tiles be square? Does it matter?
>> No
>> > * Is it better to skip tiling for small images? If so, at what threshold
>> > do you think the switch should happen? 1024?
>> I'm not sure if that has an importance. But it is not wise to have an
>> image whose one dimension is larger than the corresponding block dimension
>> (as blocks are not truncated)
>> > * Is DEFLATE preferred for compression type over LZW for lossless
>> > compression?
>> Unspecified. DEFLATE is more CPU intensive, but if network times are the
>> limiting factor, it is worth as more eficient
>> > * If the writer isn't constrained by compute power, are there preferred
>> > ZLEVEL and PREDICTOR values? Is there a time cost for decompressing
>> > ZLEVEL=9 over 1?
>> PREDICTOR has neglectable CPU inflence (just a add/diff on integer
>> values), but will not always result in smaller file sizes. Depends on the
>> dataset
>> If I trust https://github.com/inikep/lzbench , the time cost for
>> decompression for Deflate/Zlib doesn't seem to vary much with ZLEVEL. So
>> the higher the better.
>> I don't know for LZW.
>> > I'm a little confused by this code from validate_cloud_optimized_geoti
>> ff.py:
>> > if main_band.XSize >= 512 or main_band.YSize >= 512:
>> > if check_tiled:
>> > block_size = main_band.GetBlockSize()
>> > if block_size[0] == main_band.XSize and block_size[0] > 1024:
>> > errors += ["The file is greater than 512xH or Wx512," +
>> > "but is not tiled"]
>> > Will the above correctly fail an image that is (say) 256x2048 if it is
>> not
>> > tiled?
>> No, it will pass this test. Since in that case block_size[0] == xsize ==
>> 256.
>> But for such a narrow image, it should probably warn if it is not tiled,
>> as the number of strips, if letting to default strip height, will be larger
>> than really necessary.
>> Even
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
> http://schwehr.org
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180214/1ee8c61a/attachment-0001.html>
