[gdal-dev] Creating Cloud Optimized GeoTIFFs
Kurt Schwehr schwehr at gmail.com
Wed Feb 14 11:35:58 PST 2018
Added the delete and validate works now.  Thanks!
On Wed, Feb 14, 2018 at 11:28 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On mercredi 14 février 2018 11:00:01 CET Kurt Schwehr wrote:
> > (working from pretty close to head...)
> > A follow up question on how to create cogeo files...
> > I appear to need to do additional work to set BLOCK_OFFSET_?_?. How do I
> > go about this?
> > I'm trying to create a cogeo without gdal_translate in java by using
> create
> > and createcopy like this:
> > https://gist.github.com/schwehr/39680bec7fd8e3e3f840122ea3bafc65
> I guess the issue is the one mentinoned in
> http://gdal.org/java/org/gdal/gdal/Driver.html#CreateCopy-
> java.lang.String-org.gdal.gdal.Dataset-int-java.util.Vector-org.gdal.gdal.
> ProgressCallback-
> At the end of dataset manipulation, the delete() method must be called on
> the returned dataset otherwise data might not be properly flushed to the
> disk.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180214/4674739b/attachment.html>
