[gdal-dev] GDALCreateWarpedVRT and .msk files
Sean Gillies sean at mapbox.com
Sun Feb 18 21:55:16 PST 2018
Hi all,
I've noticed that while GDALCreateWarpedVRT does acquire nodata values, and
thereby nodata-derived masks, from the source dataset, it does not pick up
on a source's .msk file and does not acquire a source mask derived from
that sidecar file.
Is this an oversight or intended behavior? Is there a best practice for
adding a .msk derived mask to the VRT?
Thanks,
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180218/2f6fd9fe/attachment.html>
