[gdal-dev] GDAL way to set open options in QGIS?
Even Rouault even.rouault at spatialys.com
Mon Feb 19 04:31:19 PST 2018
Hi Jeremy,
> I've now added the VRT layer to QGIS 3.0 dev with GDAL 2.3dev, but it
> doesn't recognise it as a spatial layer - it just shows up with QGIS table
> icon. Here's the VRT file I'm trying to add and the result of ogrinfo:
> https://gist.github.com/palmerj/eb25a396fecc181b2da5023c70078198. Could the
> invalid geometries be causing the issue?
No, I did reproduce the issue. The reason was that the path to the mbtiles in the VRT was not
tagged as relative. So either add the -relative switch in your ogr2vrt.py invokation, or grab its
latest version that should now automatically set it.
> Note I can add the mbtiles file directly but then it shows all the data
> from every zoom level.
Normally only the maximum zoom level
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180219/a2e694d6/attachment-0001.html>
