[gdal-dev] GDAL way to set open options in QGIS?
Jeremy Palmer palmerjnz at gmail.com
Mon Feb 19 11:16:58 PST 2018
Hi Even,
On Tue, Feb 20, 2018 at 1:31 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> No, I did reproduce the issue. The reason was that the path to the mbtiles
> in the VRT was not tagged as relative. So either add the -relative switch
> in your ogr2vrt.py invokation, or grab its latest version that should now
> automatically set it.
Thanks Magic.  I've now got it working:
https://gist.github.com/palmerj/a52bc8357acee0cb1ddc622c2dab1e63
> > Note I can add the mbtiles file directly but then it shows all the data
> > from every zoom level.
Ok thanks good to know.
Cheers
Jeremy
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180220/1434c750/attachment.html>
