[gdal-dev] GDALCreateWarpedVRT and .msk files
Even Rouault even.rouault at spatialys.com
Tue Feb 20 03:57:49 PST 2018
Sean,
I've just tested with GDAL trunk and latest state of 2.2 branch (but I think that 2.2.2 should behave the same), and when using gdal.AutoCreateWarpedVRT() on your below mentionned dataset, the .msk file is read.
$ CPL_CURL_VERBOSE=YES CPL_VSIL_CURL_ALLOWED_EXTENSIONS=tif,msk FILE=/vsicurl/http://oin-hotosm.s3.amazonaws.com/5a324a622553e6000ce5aaf5/0/3fa181a1-425c-4e53-b49f-ea72884da097.tif python
>>> from osgeo import gdal
>> import os
>>> file = os.getenv('FILE')
>>> src_ds = gdal.Open(file)
>>> ds = gdal.AutoCreateWarpedVRT(src_ds)
* Connected to oin-hotosm.s3.amazonaws.com (52.216.130.219) port 80 (#2)
> GET /5a324a622553e6000ce5aaf5/0/3fa181a1-425c-4e53-b49f-ea72884da097.tif.msk HTTP/1.1
Host: oin-hotosm.s3.amazonaws.com
Range: bytes=49152-114687
Accept: */*
< HTTP/1.1 206 Partial Content
< x-amz-id-2: oXRmqP1A9HzNTn9soSOh9vQJzGUa+lA0GbsAKa0m51H8wvZCgS31y85NAXu60r3MMjRTz1TssYk=
< x-amz-request-id: BC46544B595F1D30
< Date: Tue, 20 Feb 2018 11:52:54 GMT
< Last-Modified: Thu, 14 Dec 2017 09:58:29 GMT
< ETag: "97b96b954a22be9d7bae0bfd1f33922b"
< Accept-Ranges: bytes
< Content-Range: bytes 49152-114687/1730078
< Content-Type: binary/octet-stream
< Content-Length: 65536
< Server: AmazonS3
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180220/132b4559/attachment.html>
