[gdal-dev] int versus bool in C++ method args
Even Rouault even.rouault at spatialys.com
Tue Feb 20 10:37:25 PST 2018
On mardi 20 février 2018 07:23:48 CET Kurt Schwehr wrote:
> Hi Even,
> With https://trac.osgeo.org/gdal/changeset/41510, would it be possible to
> use a bool for bDelete since this is a member of a C++ class?  Any C API
> call could easily convert from an int to a bool and then we have cleaner
> internals for the C++ side of the house.  Or is there some other reason
> that had you using an int boolean?
> OGRErr          removeCurve( int iIndex, int bDelete = TRUE );*
Hi Kurt,
good point. I blindly copied it from similar OGRGeometryCollection::removeGeometry()
Just changed the new methods to use bool
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180220/2920d638/attachment-0001.html>
