[gdal-dev] Proposed updates to the GDAL feature style spec
Tue Jan 2 23:13:28 PST 2018
Alan,
I'm also supportive of your change while not having a strong opinion
on the ogr-brush-1 issue.  Thanks for showing some love to feature
styles *including* the specification.
Best regards,
Frank
On Wed, Jan 3, 2018 at 12:52 AM, Alan Thomas
<athomas at thinkspatial.com.au> wrote:
> Thanks for the feedback, Even. If there is no other feedback in the
> next few days I will merge the change, as well as an extra code fix to
> implement change 8.
> On 2 January 2018 at 21:47, Even Rouault <even.rouault at spatialys.com> wrote:
>>> 5. [...] change the definition of
>>> ogr-brush-1 to mean a solid fill in the selected background color;
>>> change the suggested default for BRUSH bc to transparent
>>> (#FFFFFF00).
>> I'd suggest that we add a rule so as to keep the current semantics: if
>> ogr-brush-1 is used, then bc must be omitted (or set to a color with
>> alpha=0). It would be confusing to have the possibility to have 2 ways to
>> express a solid fill with either ogr-brush-0 + fc or ogr-brush-1 + bc. So
>> people wanting a solid fill should use ogr-brush-0 (or don't specify it)
> I expected that this might be a problematic change. I'm happy to leave
> ogr-brush-1 alone. If existing code is already special-casing
> ogr-brush-1, then keeping the spec the way it is would be less
> confusing.
> Therefore line 492 will say "null brush (transparent - no fill,
> irrespective of fc or bc values)".
> Alan
> Alan Thomas
> Software Developer
> ThinkSpatial
> http://www.thinkspatial.com.au
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
light and sound - activate the windows |
and watch the world go round - Rush    | Geospatial Software Developer
