[gdal-dev] Prevent extrapolating with ReadAsArray when resampling
Even Rouault even.rouault at spatialys.com
Fri Jan 5 05:48:54 PST 2018
Rutger,
ReadAsArray() / IRasterIO() with non-nearest resampling use the interpolation code of
overview building (except for Lanczos where it uses the warping code), which was of course
targetted at downsampling rather than upsampling. Nodata is taken into account when
mixing together source pixels for a target pixel (those pixels are assigned a zero weight in
convolution computations), but it seems that we should likely skip entirely a target pixel if
the center source pixel corresponding to it is nodata, so that nodata areas do not fade
away (which is done in the warping code). What surprises me is that you get different
results depending on the nodata value (I could also see that)
Regarding Lanczos, might be a bug specific to it indeed. Didn't look.
Perhaps file this as a ticket about this.
Even
> Dear list,
> I regularly use (and enjoy!) the resampling option when using the
> ReadAsArray method of a Dataset. However, i noticed that in the case of
> nodata values in the raster, the method extrapolates "into" those nodata
> values. This is not always desirable in my case, especially when using any
> resampling algorithms other than Bilinear or Nearest, since these can
> overshoot significantly.
> This made me wondering if there is a way to prevent this extrapolation? One
> thing i noticed it that when the nodata value is non-numerical, like NaN,
> there is a lot less extrapolation (eg more nodata values returned). That
> could be used a workaround, but it not convenient to map numerical nodata to
> NaN values before reading the input.
> In the process of exploring the behavior, i also encountered some issues
> (perhaps a bug?) when using Lanczos in combination with certain datasets and
> certain output grids. This happened especially when the output size is an
> uneven factor of the input size, like (buf_xsize=xsize*3,
> buf_ysize=ysize*3) or (buf_xsize=xs*5, buf_ysize=ys*5) etc.
> Here is a notebook showing what i did with a linearly increasing grid:
> https://gist.github.com/RutgerK/30fbd03d9b2ab79861eedfbb95064732
> And a random grid:
> https://gist.github.com/RutgerK/bdbd6c124224cf49961082e1620ce604
> Regards,
> Rutger
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180105/d2886b36/attachment.html>
