[gdal-dev] CPLJSONDocument
Kurt Schwehr schwehr at gmail.com
Fri Jan 5 07:54:18 PST 2018
+1 for wrapping the old C code in some cleaner abstractions!
But +10 for switching to a from the ground up C++ JSON library unless there
are clear reasons for a core C library (I don't think there are)
If we are talking about this kind of code, there are several things that
have bugged me in general about GDAL for a long time.
* Passing char *psz yada all over the place in pure C++ code.  A const
std::string is usually not a noticeable expense and is a lot safer
* CPLString when std::string will do just fine.  And we can write free
functions to operate on strings.  I'm generally bothered by subclassing of
std::string as CPLString.  After reading large amounts of C++ code, I think
it adds more confusion than it ever helps over having clean free
functions.  Interop and analysis with CPLString's is no fun.
https://stackoverflow.com/questions/6006860/why-should-one-not-derive-from-c-std-string-class
-kurt
On Fri, Jan 5, 2018 at 7:44 AM, Sean Gillies <sean at mapbox.com> wrote:
> Hi Dmitry,
> I scanned the PR and it seems reasonable to me. I'm barely a C++
> programmer at all and it's clear to me, more clear than before. That said,
> I'm not a fan of wrapping things that could be replaced. Have you looked
> into whether a more performant C++ JSON library could be used? I haven't
> run the benchmarks, but json-c compares pretty poorly to others in
> https://github.com/miloyip/nativejson-benchmark.
> On Wed, Jan 3, 2018 at 12:04 PM, Dmitry Baryshnikov <bishop.dev at gmail.com>
> wrote:
>> Hi everybody,
>> Happy new year and lot of success in 2018!
>> I would like to discuss my pull request https://github.com/OSGeo/gdal/
>> pull/282
>> I created a thin wrapper around the json-c library which wide using in
>> GDAL.
>> This is C++ interface which hides C memory management and provides nice
>> API. The web or disk json documents reading chunk by chunk with progress
>> indication also added.
>> In future, the json-c can be easily switch to something other without
>> breaking the existing code.
>> The CPLJSONDocument/CPLJSONObject/CPLJSONArray usage examples can be
>> found in frmts/pds driver and c++ unit test in autotest/cpp/test_cpl.cpp.
>> Is this ready to merge into the trunk? Any objections?
>> Best regards,
>>     Dmitry
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Sean Gillies
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180105/3dadbae0/attachment.html>
