[gdal-dev] CPLJSONDocument
Dmitry Baryshnikov bishop.dev at gmail.com
Fri Jan 5 12:19:05 PST 2018
Hi Sean,
First of all I agreed with Kurt. Json-c is GDAL internal library and had
inspected by fuzzer.
Also json-c widely used in GDAL:
gdal/gcore
gdal/ogr/ogrsf_frmts/carto
gdal/ogr/ogrsf_frmts/amigocloud
gdal/ogr/ogrsf_frmts/cloudant
gdal/ogr/ogrsf_frmts/plscenes
gdal/ogr/ogrsf_frmts/geojson
gdal/ogr/ogrsf_frmts/gmlas
gdal/ogr/ogrsf_frmts/elastic
gdal/ogr/ogrsf_frmts/couchdb
gdal/ogr
gdal/frmts/rda
gdal/frmts/arg
gdal/frmts/mbtiles
gdal/frmts/plmosaic
gdal/frmts/pds
It's big work to replace json-c in all code smoothly.
Best regards,
     Dmitry
05.01.2018 19:05, Kurt Schwehr пишет:
> I think the more important factors than speed for a C++ lib are: security,
> stability, maintainability, and memory usage (low stack usage and
> constrainable heap).
> I really don't want to have us go through yet more piles of fuzzer bugs for
> a library we depend on.  It would be nice to have that already done well by
> the lib.
> On Fri, Jan 5, 2018 at 7:54 AM, Kurt Schwehr <schwehr at gmail.com> wrote:
>> +1 for wrapping the old C code in some cleaner abstractions!
>> But +10 for switching to a from the ground up C++ JSON library unless
>> there are clear reasons for a core C library (I don't think there are)
>> If we are talking about this kind of code, there are several things that
>> have bugged me in general about GDAL for a long time.
>> * Passing char *psz yada all over the place in pure C++ code.  A const
>> std::string is usually not a noticeable expense and is a lot safer
>> * CPLString when std::string will do just fine.  And we can write free
>> functions to operate on strings.  I'm generally bothered by subclassing of
>> std::string as CPLString.  After reading large amounts of C++ code, I think
>> it adds more confusion than it ever helps over having clean free
>> functions.  Interop and analysis with CPLString's is no fun.
>>    https://stackoverflow.com/questions/6006860/why-should-
>> one-not-derive-from-c-std-string-class
>> -kurt
>> On Fri, Jan 5, 2018 at 7:44 AM, Sean Gillies <sean at mapbox.com> wrote:
>>> Hi Dmitry,
>>> I scanned the PR and it seems reasonable to me. I'm barely a C++
>>> programmer at all and it's clear to me, more clear than before. That said,
>>> I'm not a fan of wrapping things that could be replaced. Have you looked
>>> into whether a more performant C++ JSON library could be used? I haven't
>>> run the benchmarks, but json-c compares pretty poorly to others in
>>> https://github.com/miloyip/nativejson-benchmark.
>>> On Wed, Jan 3, 2018 at 12:04 PM, Dmitry Baryshnikov <bishop.dev at gmail.com
>>>> wrote:
>>>> Hi everybody,
>>>> Happy new year and lot of success in 2018!
>>>> I would like to discuss my pull request https://github.com/OSGeo/gdal/
>>>> pull/282
>>>> I created a thin wrapper around the json-c library which wide using in
>>>> GDAL.
>>>> This is C++ interface which hides C memory management and provides nice
>>>> API. The web or disk json documents reading chunk by chunk with progress
>>>> indication also added.
>>>> In future, the json-c can be easily switch to something other without
>>>> breaking the existing code.
>>>> The CPLJSONDocument/CPLJSONObject/CPLJSONArray usage examples can be
>>>> found in frmts/pds driver and c++ unit test in autotest/cpp/test_cpl.cpp.
>>>> Is this ready to merge into the trunk? Any objections?
>>>> Best regards,
>>>>      Dmitry
