[gdal-dev] Why is CSLUniquePtr internal?
Kurt Schwehr schwehr at gmail.com
Mon Jan 8 09:24:31 PST 2018
Since the C style string lists get exposed so often in the API, I am
strongly in favor of exposing it and encouraging its use.
I am of the opinion that modern C++ code should rarely use bare
malloc/free/new/delete and variants of those (doubly strong for the delete
side) .
Anyone have a reason to not expose it?
On Mon, Jan 8, 2018 at 9:15 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On lundi 8 janvier 2018 09:08:44 CET Kurt Schwehr wrote:
> > Even,
> > In https://trac.osgeo.org/gdal/changeset/41104, you put CSLUniquePtr
> > behind GDAL_COMPILATION. Can you explain why? I would like to use it in
> > some of my code rather than the usual MakeCleanup with CPLDestroy that I
> > usually do.
> I didn't really feel that needed to be part of the API. I don't have a
> strong opinion on this though
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180108/48d71895/attachment.html>
