[gdal-dev] GDALWARP Error
Rasika Chinchwade rasikachinchwade31 at gmail.com
Mon Jan 15 23:51:56 PST 2018
Please guide me so that I will not stuck at this problem.
I have used STD dataset of INSAT-3D
https://www.mosdac.gov.in/catalog?field_satellitenode_nid=69
you can download the datset from www.mosdac.gov.in
HEM daily ,LST product. product of INSAT3D .This all are in disc shape.
I am trying to convert the .h5 dataset to GeoTiff format using gdal.
This products are giving me lat,lon in 2D array which are unevenly spaced
and also having scaling factor of 0.01
GDALINFO:
  gdal version is 2.2.1 released on 2017-06-03
Why I am getting this error while performing same operation on same dataset
given on link
https://gis.stackexchange.com/questions/253884/projecting-
insat3d-l1b-data-from-hdf5-to-geotiff
ERROR 1: tolerance condition error
ERROR 1: Reprojection failed, err = -20, further errors will be suppressed
on the transform object.
0...10...20...30...40...50...60...70...80...90...100 - done.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180116/64be0e0c/attachment-0001.html>
