[gdal-dev] Resulting geometry from OGRGeometry::difference somehow got simplified
Even Rouault even.rouault at spatialys.com
Thu Jan 18 06:44:32 PST 2018
On lundi 15 janvier 2018 16:49:57 CET mikeucfl wrote:
> Just to add some more information.. upon some further inspection it seems
> all the values are snapped to a grid. All my geometry is in a WGS84
> (EPSG:4326) projection, and the values are snapped to a 0.01 lat/long grid.
> I don't do anything to set a tolerance or anything for these values, or see
> where I could set these from the GDAL layer (as the driver I'm using wraps
> most of the functionality for the FGDB database using the ESRI FileGDB
> driver)
The FileGDB format using integer storage with a precision for coordinates. Perhaps this
is a missconfiguration of this precision when you have created your FGDB database ?
I guess you would have the same issue if you just read or ogr2ogr the source layer
without doing any processing on it.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180118/283eda9c/attachment.html>
