[gdal-dev] Compile gdal with expat support on AWS Linux
Even Rouault even.rouault at spatialys.com
Sat Jan 20 04:08:49 PST 2018
On samedi 20 janvier 2018 12:04:42 CET Tobias Reinicke wrote:
> Hello,
> I've been trying to get gdal compiled to be able to read GML files - but I
> keep on getting expat / Xerces errors.
> I am working on an AWS AMI that matches the AWS Lambda environment (as I'm
> trying to get this working in Lambda really).(AMI:
> amzn-ami-hvm-2017.03.1.20170812-x86_64-gp2 / amiId: ami-ebd02392)
Tobias,
If you did a first GDAL build without expat support, and then ran ./configure and make
again, some files have not been recompiled, so do a "make clean" and build again.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180120/25ecac53/attachment.html>
