[gdal-dev] ogrInfo error - Entry Point Not Found
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Jan 29 06:39:54 PST 2018
Hi John,
I see this quite often with MS4W installations.  For testing, you might
want to temporarily rename your C:/Program Files/PostgreSQL/ folder to
something like PostgreSQL-test and then open a new Command Prompt window
and re-run:   ogrinfo
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2018-01-28 8:04 PM, john polo wrote:
> Hi,
> I am attempting to use ogrInfo to get information about a geodatabase. I
> am using Windows 7 64bit. I have GDAL  installed with QGIS. The QGIS is
> 2.18.3, but I can't find how to tell the version of GDAL that's
> installed. I don't know much about working with a lot of the OSGeo4W64
> software, especially when it comes to software libraries, please bear
> with me if I do not provide the necessary information.
> I looked up how to read the geodatabase with PostgreSQL. It seems I need
> to first use ogrInfo to read what's in the geodatabase and then maybe
> get PostGIS involved. This will probably lead to another question on
> another list. :) Anyway, on the Windows command prompt, I used
> ogrInfo C:\directories\geodatabase.gdb
> and I get this error:
> "ogrinfo.exe - Entry Point Not Found
> The procedure entry point SSL_COMP_free_compression_methods could not be
> located in the dynamic link library SSLEAY32.dll
> When I searched for "SSL_COMP_free_compression_methods", several of the
> results included references to OpenSSL. Like this one:
> https://www.openssl.org/docs/manmaster/man3/SSL_COMP_add_compression_method.html
> I am unsure if the problem exists in OpenSSL or in GDAL/ogrInfo. I would
> appreciate someone explaining how I can address the problem so that I
> can use ogrInfo.
> John
