[gdal-dev] SPOT7 DIMAP driver for tiled datasets has no lat/lon
Even Rouault even.rouault at spatialys.com
Tue Jan 30 08:28:06 PST 2018
On mardi 30 janvier 2018 16:00:25 CET Gong, Shawn wrote:
> Hi Even,
> Your fix did remove the wrong georeferencing info. Thank you!
> But I still need to run 'gdalwarp -rpc' to apply the georeferencing. It
> would be great if the GDAL driver can perform this extra step.
This is not in the philsophy of GDAL drivers to apply such non-trivial processing steps.
They try to expose the data & metadata as close as possible to the original values. And
RPC warping is non-trivial since to get the optimum results you need to provide a DEM.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180130/63ef69d2/attachment.html>
