[gdal-dev] ERROR 6: Failed to initialize PROJ.4 with "..."
Chris Marsh chris.marsh at usask.ca
Tue Jan 30 15:01:38 PST 2018
To close the loop on this, it was a name conflict with the proj4 that is in
VTK
Details here:
http://vtk.1045678.n5.nabble.com/Don-t-build-vtkproj4-tp5746073p5746269.html
Thanks everyone for their help
Cheers
Chris
On 28 October 2017 at 11:26, Chris Marsh <chris.marsh at usask.ca> wrote:
> Hi all,
> I posted this to the proj4 mailing list and they seem pretty convinced
> this is a GDAL problem.
> I have tried the September gdal 2.2.2 build as well as the latest GDAL git
> build, and finally have them building thanks to Even's help.
> However, now GDAL just segfaults within the pj_init_ctx. As a reminder,
> it's something odd about this env as this work works flawlessly on multiple
> computers.
> Would appreciate any help,
> Cheers
> Chris
> [debug]: Reading forcing file data
> src/tcmalloc.cc:284] Attempt to free invalid pointer 0x2aaaafa4df20
> Thread 1 received signal SIGABRT, Aborted.
> 0x00002aaac4900214 in raise () from /cvmfs/soft.computecanada.ca/
> nix/var/nix/profiles/16.09/lib/libc.so.6
> (gdb) bt
> #0  0x00002aaac4900214 in raise () from /cvmfs/soft.computecanada.ca/
> #1  0x00002aaac490167a in abort () from /cvmfs/soft.computecanada.ca/
> #2  0x00002aaab5bd5748 in tcmalloc::Log (mode=mode at entry=tcmalloc::kCrash,
> filename=filename at entry=0x2aaab5bea66e "src/tcmalloc.cc", line=line at entry=284,
> a=..., b=..., c=..., d=...) at src/internal_logging.cc:118
> #3  0x00002aaab5bca14f in (anonymous namespace)::InvalidFree
> (ptr=<optimized out>) at src/tcmalloc.cc:284
> #4  0x00002aaab5fe7dde in pj_dealloc (ptr=<optimized out>) at
> pj_malloc.c:129
> #5  0x00002aaab5fe7ed1 in pj_default_destructor (P=P at entry=0x13c2b40,
> errlev=errlev at entry=-7) at pj_malloc.c:198
> #6  0x00002aaab5fe7234 in pj_init_ctx (ctx=ctx at entry=0x2aaab6219b20
> <default_context>, argc=<optimized out>, argv=argv at entry=0x7fffffff7a50)
> at pj_init.c:672
> #7  0x00002aaab5fe7615 in pj_init_plus_ctx (ctx=0x2aaab6219b20
> <default_context>, definition=0x24863340 "+proj=aea +lat_1=20 +lat_2=60
> +lat_0=40 +lon_0=-96 +x_0=0 +y_0=0 +ellps=GRS80 +datum=NAD83 +units=m
> +no_defs ")
>     at pj_init.c:411
> #8  0x00002aaab4a71dc8 in OCTProj4NormalizeInternal(char const*) () from
> /home/cmarsh/CHM/build-release/lib/gdal/lib/libgdal.so.20
> #9  0x00002aaab4a71ee6 in OCTProj4Normalize () from /home/cmarsh/CHM/build-
> #10 0x00002aaab4a530ec in OGRSpatialReference::importFromProj4(char
> const*) () from /home/cmarsh/CHM/build-release/lib/gdal/lib/libgdal.so.20
> #11 0x0000000000520a61 in core::config_forcing (this=this at entry=0x7fffffffab50,
> value=...) at /home/cmarsh/CHM/src/core.cpp:311
> #12 0x0000000000527041 in core::init (this=this at entry=0x7fffffffab50,
> argc=argc at entry=3, argv=argv at entry=0x7fffffffafe8) at
> /home/cmarsh/CHM/src/core.cpp:1119
> #13 0x00000000004f502f in main (argc=3, argv=0x7fffffffafe8) at
> /home/cmarsh/CHM/src/main.cpp:17
> Chris Marsh
> PhD Candidate
> chrismarsh.ca
> 121 Research Drive
> University of Saskatchewan
> On 19 October 2017 at 13:41, Chris Marsh <chris.marsh at usask.ca> wrote:
>> echo 2 49 |  /build-release/lib/gdal/bin/gdaltransform -s_srs EPSG:4326
>> -t_srs "+proj=aea +lat_1=20 +lat_2=60 +lat_0=40 +lon_0=-96 +x_0=0 +y_0=0
>> +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs" --debug on
>> OGRCT: PROJ >= 4.8.0 features enabled
>> OGRCT: Using locale-safe proj version
>> OGRCT: Source: +proj=longlat +datum=WGS84 +no_defs
>> OGRCT: Target: +proj=aea +lat_1=20 +lat_2=60 +lat_0=40 +lon_0=-96 +x_0=0
>> +y_0=0 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs
>> OGRCT: Source: +proj=aea +lat_1=20 +lat_2=60 +lat_0=40 +lon_0=-96 +x_0=0
>> OGRCT: Target: +proj=longlat +datum=WGS84 +no_defs
>> 5634252.86902731 4265258.45946341 0
>> On 19 October 2017 at 13:34, Even Rouault <even.rouault at spatialys.com>
>> wrote:
>>> On jeudi 19 octobre 2017 13:19:52 CEST Chris Marsh wrote:
>>> > Hi,
>>> > I build GDAL by specifying --with-static-proj4  on the configure
>>> command
>>> > line. This does not seem to have resolved the problem.
>>> > echo 2 49 | build-release/lib/gdal/bin/gdaltransform -s_srs EPSG:4326
>>> > > -t_srs EPSG:32632
>>> > > -11818.9526229417 5451106.95020125 0
>>> OK, so GDAL and proj.4 have some minimum level of functionnality
>>> And what about
>>> echo 2 49 |  gdaltransform -s_srs EPSG:4326 -t_srs "+proj=aea +lat_1=20
>>> +lat_2=60 +lat_0=40 +lon_0=-96 +x_0=0 +y_0=0 +ellps=GRS80
>>> Spatialys - Geospatial professional services
>>> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180130/6f6787d1/attachment.html>
