[gdal-dev] Cache when dealing with several processes and COG
Sean Gillies sean at mapbox.com
Tue Jul 3 09:34:32 PDT 2018
Hi Guy,
On Tue, Jul 3, 2018 at 12:06 AM Guy Doulberg <guyd at satellogic.com> wrote:
> Hi guys,
> I am working on a tileserver use case on top of cogs.
> I  want to find a cache mechanism to my architecture.
> The tile-server architecture is several python processes(gunicorn) running
> on several VMs.
> I understand how GDAL caches the curl blocks or the raster using
> intra-process caching, but I can't use this cache in the other
> processes/vms.
> I was thinking maybe to use some kind of http proxy server that will cache
> the bytes content retrieved from the http server holding the cogs (Azure
> blob storage)
> There is some data that can be reused(therefore cached) across all tile
> requests for example:
> 1. The file size (HEAD)
> 2. The first header block
> 3. The other header blocks
> 4. maybe in some cases the image blocks themselves (in case you take the
> same blocks all the time but change something in the presentation layer)
> did any of you tried this architecture or used a different way to cache
> across servers?  maybe there is a way to share GDAL_CACHE across process
> that I missed?
> Thanks,
> Guy
Nginx advertises some support for byte range caching that I've been meaning
to try: https://www.nginx.com/blog/smart-efficient-byte-range-caching-nginx/
My own strategy so far has been to deploy to the same cloud as the data and
profit from higher bandwidth and not to think about caching very much at
all.
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180703/ace2cd8e/attachment.html>
