[gdal-dev] FITS format not listed in gdalinfo --formats
Susan Borda sborda at umich.edu
Thu Jul 5 09:58:26 PDT 2018
Thanks Evan, I saw that mentioned in the formats list but I'm not sure how
to "build GDAL" with this library. I just downloaded GDAL and it uses
Python 3.6 but the version of CFITSIO I found uses Python 2.x. I'm using a
Mac but can easily run all of this on Linux VM if need be.
-susan
On Thu, Jul 5, 2018 at 12:45 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> On jeudi 5 juillet 2018 12:41:08 CEST Susan Borda wrote:
> > Hi-
> > I'm new to gdal and am trying to use gdalinfo to read a *.fits file
> > (astronomy files), specifically the header. When I list the formats
> > supported by gdalinfo, I'm only seeing FIT not FITS. Is FITS no longer
> > supported?
> It is, but you must build GDAL against the CFITSIO library:
> http://gdal.org/frmt_various.html#FITS
> On Debian and derivatives, this is the libcfitsio-dev package.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Susan Borda
Data Workflows Specialist
Research Data Services
University of Michigan Libraries
3175 Shapiro Library
734-764-9134 | sborda at umich.edu
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180705/f182ca3f/attachment.html>
