[gdal-dev] GDAL 2.3.1 on linux disregarding nodata values
    Even Rouault
    even.rouault at spatialys.com
    Fri Jul  6 05:09:49 PDT 2018
On vendredi 6 juillet 2018 14:00:16 CEST Tom van Tilburg wrote:
> I just did a fresh build of trunk (2.4.0) but noticed 2 issues:
> 1. The installed version in /usr/local/bin is still version 2.3.1:
You may have to defined LD_LIBRARY_PATH since it probably links against your
system libgdal
Otherwise you don't need to install the master, but just make and source the
scripts/setdevenv.sh that will set PATH, LD_LIBRARY_PATH, GDAL_DATA and
PYTHONPATH to appropriate values in the built tree.
http://www.spatialys.com
