[gdal-dev] Dissolve large amount of geometries
Paul Meems bontepaarden at gmail.com
Mon Jul 16 12:27:52 PDT 2018
I took the advice of Andreas and converted my code to using PostGIS.
And the speed difference is enormous.
The commands I've used:
// Import shapefile into PostGIS:
ogr2ogr -f PostgreSQL PG:"host=localhost user=..." fishnet.shp -gt
unlimited -lco GEOMETRY_NAME=geom -a_srs "EPSG:28992"
// Add random data:
ogrinfo PG:"host=localhost user=..." -sql "ALTER TABLE fishnet ADD COLUMN
randField integer;UPDATE fishnet SET randField = ceil(RANDOM()*10);CREATE
INDEX randfield_idx ON fishnet (randField);
// Dissolve:
ogrinfo PG:"host=localhost user=..." -sql "CREATE TABLE dissolved AS SELECT
randfield, ST_Multi(ST_Union(f.geom)) AS geom FROM fishnet AS f GROUP BY
randfield"
// Export to shapefile
ogr2ogr -f "ESRI Shapefile" taskmap.shp PG:"host=localhost user=..." -sql
"SELECT randfield, (st_dump(geom)).geom AS geom FROM dissolved" -overwrite
-gt unlimited
// Clean up:
ogrinfo PG:"host=localhost user=..." -sql "DROP TABLE IF EXISTS fishnet
CASCADE;DROP TABLE IF EXISTS dissolved CASCADE"
The timing of the steps, after I converted the above commands to C#:
| #shapes |Import     |Add values |  Dissolve |    Export |
|1,677    |00:00:00.29|00:00:00.14|00:00:00.10|00:00:00.05|
|4,810    |00:00:00.28|00:00:00.20|00:00:01.11|00:00:00.15|
|18,415   |00:00:00.78|00:00:00.53|00:00:04.57|00:00:00.31|
|72,288   |00:00:02.07|00:00:02.13|00:00:22.56|00:00:01.02|
|285,927  |00:00:07.58|00:00:06.68|00:01:59.59|00:00:03.82|
|1,139,424|00:00:26.63|00:00:33.51|00:11:34.63|00:00:15.19|
|4,546,854|00:01:46.19|00:03:51.92|01:10:07.41|00:00:57.51|
4.5 million squares of 0.3m have a total area of about 40 ha.
That is good enough for me. The total time will be around 80 min, instead
of days using SQLite.
I'm assuming I can't speed up this command anymore, right?
randfield"
Thanks all for your valuable help.
Regards,
Paul
Op ma 16 jul. 2018 om 11:30 schreef Andreas Oxenstierna <ao at t-kartor.se>:
> ST_Union in PostGIS should scale better than SQLite.
> ST_Dump gives you singlepart geometries.
> Best Regards
> Andreas Oxenstierna
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180716/2ae345ce/attachment.html>
